Over the weekend I managed to replace my Radiator, Fan with Clutch and Serpentine Belt. Flushed and put 50/50 coolant. I had to opening the Air filter housing, MAF. Since I opened up the Throttle Valve decided to spray and clean (may be i didn't clean enough)
Now the idle is running little high and fan is making little more noise (whoosh) than the stock fan I had before. Any explanation? It's the low speed issue on the hwy it seems ok.
Will appreciate any suggestion.
Thanks :confused
Thanks :confused
