1 - 15 of 15 Posts
Thank you in advance for any help.
I have a '94 Dicovery v8i. It has 120K miles.
I was driving last week, and noticed a lag between 1k and 3K.
A few days later the battery light came on, and the tach stopped working. The next day, the check engine light came on. The next day, it died as if a battery/alternator. Had them checked, not that. Also replaced the coil.
A mechanic who works with Brit. autos says he thinks it is a a wire grounding out in the column/ignition swith. This just not seem right to me.
Sound Familiar?
MG
Who did you have check out the alternator? They may have checked out the alt while it was working per specs (isn't that a corollary of Murphy's Law?).
It sounds exactly like what my '95 DI V8i did several times now - the trick is that it is an intermittent failure that eventually leaves you driving exclusively off your battery (make sure you've got a good charge!). It's as it had been warning me for weeks before it finaly gave up.
I believe that the diode(s) (not sure on terminology, as I have to translate the technitian's babble from Spanish) were the culprit in my case.
In any case, after three rebuilds of the same alt, I've gone and upgraded to a Mean Grean heavy duty replacement.
Good luck and welcome to LRO! Any pics of your rig?
Thanks for the info.
The Alt was tested at autozone and I would assume that the mechanic has checked it as well since it has been in his shop.
Did you have the same symptoms with the tach?
I don't understand why there would be a lag at certain RPM with an Alternator problem, unless it is creating a draw on the battery.
When pumped up to 5000K the battery light goes out, then come back on immediatly, which again points to the alternator.
TRhanks for everyones help.
-Kevin
textbook case of pre-failure alternator flakiness. Get a good one, don't mess with Autozone unless you like getting a new one every year. Denso makes them under license from Marelli, so the OEM replacement ones are quite nice compared to the earlier ones.
Stick a new tensioner on there since you'll have the belt off etc- they tend to go soon after 120K or so.
Ditto, my alternator worked intermittently with the exact same symptoms before finally kicking the bucket. I would NOT recommend a MeanGreen. I went that route and ended up with a cooked battery and fuse box. They would not return calls or emails when I tried to get a replacement under warrantee. I eventually had to have my credit card company go after them.
That's a good question, Felix! I had my original rebuilt, but a year later it's sounding like the bearing it going out. So I guess I'm in the same boat, trying to decide on having mine rebuilt again, or get a replacement.
Buy a new one. A brand new one. Not some half-assed rebuilt that leaves you stranded at the worst time. I bought a NAPA rebuilt, it was in stock locally, and am on my second one. I carry a spare always. I've since found a vendor in NY who sells brand new Marelli units for $170 or so, they're on special for December at $150. I'd suggest the 120A RR alternator, slight modification to the power wire required. The 100a unit has a 6mm stud, the 120a has an 8.
So, frickjp, how can I get one one of these brand new Marelli's for $150?
I'd be willing to paypal the money plus shipping, if you'd be willing to send one to me.
MG
If your alt is warm to the touch after a full night's rest, I would lay money on the need for a new one...
Forward!
errant said:
My new alternator arrived today. Going to switch it out tomorrow :)
$166 including shipping from http://www.iat-usa.com/
Thanks for the tip, frickjp :clap:
Hey errant, thanks for the link!!!! I know that will come in very usefull in the near future. What exactly do you need to do to the power wire to make the RR unit work?
I went with the stock Disco alternator, not the RR alt, Badger. Maybe frickjp can tell us how it's done?
1 - 15 of 15 Posts
