For a few weeks now, I'm only able to remove my key from the ignition on my D1 about 50% of the time. Thinking it was related to steering wheel position for some reason (steering wheel lock would also not engage), I would restart the vehicle, reverse, wiggle the wheel, drive forward, wiggling the steering wheel, and then try again. Usually after 2-4 times of restarting the vehicle I'd finally get the key out. Seems to work best with the wheel centered. After doing a little troubleshooting today I find that it is electrical in nature... with power removed (battery disconnected) I can remove the key easily and the wheel will lock when turned.
My initial thoughts are that this is an ignition switch going bad, or a rotary coupler in the steering wheel assembly on its last legs. I've seen on this forum before a couple of similar problems with folks mentioning to use graphite lubricant. I don't think that will solve this as the key is easily inserted/removed with electrical power removed. I also tried the transmission selector wiggle method mentioned to Serg quite a while back - no joy.
Serg, did you ever fix your problem when you had it with the RRC? Anyone else have suggestions, thoughts, ideas, prayers to the Rover Gods?
Thanks!
Bender
Thanks!
Bender
