1 - 5 of 5 Posts
I've got a '96 Disco that was in dire need of new plugs and ignition wires. In the process of installing a wrong set of wires I received from Atlantic British (they sent me the set that went with a distributor), I think I mixed up the sequence from the coil block to the cylinders. Can anyone enlighten me as to which coil block socket goes with which cylinder?
Thanks,
SRR
OK...bear with me on this...
coil block 1 2 3 4 5 6 7 8
engine 8 7
6 5
4 3
2 1
Front
OK, follow me on this...the first number will be the coil block number and the second will be the engine cylinder. I am not a mechanic so I figured this the best I could by looking at my engine. I may have the names messed up but this should help you:
1 - 2
2 - 5
3 - 4
4 - 7
5 - 8
6 - 3
7 - 6
8 - 1
Got it? Hope this is clear enough for you. Any more questions, just call me (209) 585-5265.
Steven
1 - 5 of 5 Posts
