Good day all
My SIII has recently begun acting funny when I start it. Here's the symptom and tell me what you think I should test.
When starting the engine - key in starting position starter spins nicely, the engine only gets enough spark when I put the key from "start" to "on", she fires right up smooth idle and plenty of power.
I have removed points and added Pertronix years ago, recent Lucas coil, replaced ignition switch which made no difference.
Voltage at the (+) coil when key is in the “on” position is 11.4, and 9.4 V when in the “start” position, and 12.4 at the battery terminals
thanks for any ideas
Herman
1973 88 NADA -
Herman
1973 88 NADA -
