1 - 5 of 5 Posts
Recently Installed a new ECM and Immobiliser still not starting. I am pretty sure It is Immobilized. I called Land Rover and explained what I needed to see if they have the capability and they seemed clueless and told me I needed to buy new modules that used ones won't work. Can anyone with any experience with testbook or other experience let me know the steps needed to relearn the immobilizer and ECM together so I can communicate it to them exactly what needs to be done? THANKS! Any info helps!
2003 Discovery 2 SE7
You will need a special Land Rover specific tool to reprogram the immobilizer to the car. ECM won’t work unless you buy new or reflash it to your VIN
First off let’s start with some nomenclature
as you are in the US, it is highly unlikely you have an immobilizer on a DI
I suspect what you replaced was the ECU and the 10-AS alarm unit
The 10-AS is a green box with IIRC a white and black multi-pin connector
Now that we have our verbiage correct (or suspect correct) we can get to the horn of the dilemma
First, why did you feel the need to replace one, or the other?
What was it doing that you did not want it to do???
The answer to this question will help me to determine if these components were in fact the root cause of your problem.
Once I know the answer to this question, I can move on to trying to help you resolve the condition.
Discussion Starter · #4 ·
The 10AS let the smoke out, burnt PCB circuit board. No door locks or crank after. Attempted to repair the circuit board and got it to run once after that. So I swapped in a new 10AS and ECM from a donor car, started once locks worked then once I parked it it never started.
when you turn the key to “start” do the instrument panel lights extinguish?
let’s try to narrow this down to a vehicle wiring issue, or ECM/10-AS issue
in the past 22 years of working solely on these silly trucks that I stupidly and completely irrationally love, I have not encountered this situation
  • Like
Reactions: V50_M66
1 - 5 of 5 Posts
