Could be leaking valve cover gaskets. You need a 8mm 12pt socket to tighten them.
I would tighten the valve covers, then clean the engine, then look leaks.
Thanks! Where are the bolts that need tightened? I've downloaded the RAVE, maybe you could point me to a specific page?Could be leaking valve cover gaskets. You need a 8mm 12pt socket to tighten them.
