1 - 4 of 4 Posts
Discussion Starter #1
hello all I am a new member here
I ask you could upgrade the dashboard range Rover 2007 to LCD instrument culstaer range Rover 2014 And then add
canbus filter . Is this upgrade available .
thank you very much all I need your opinions
If the CAN Bus versions were the same, in theory it is possible, however I think the standard frame format was changed around 2011 or 2012, so you would have to investigate. To decode those CAN Bus messages you would need an interface to the bus and some way/software to read out the interchanges. To get a rough idea of what is involved, have a peek at https://www.csselectronics.com/screen/page/simple-intro-to-can-bus/language/en#CAN-Bus-Intro-Dummies-Basics . This would be a difficult project, but a determined person with sufficient resources can usually achieve success...
Update if you make any progress here the tft insturment pack is better looking than the 2019 and i would very much be interested in swapping it into other years.
1 - 4 of 4 Posts
