My roof lining is starting to sag has anybody got a fix ? Not keen on ripping the whole lining out and getting it recovered. :lol:
There is decomposed material underneath the lining but it's usually the old glue. If you rub the lining prior to squirting the glue it should hold, and if you use the syringe trick, I doubt you will ever notice where you applied it. You might get tired arms holding up the section you glued waiting for it to dry though.aussie disco97 said:The problem with squirting in glue, is there is probably a lot of dusty, decomposing sponge type material underneath the lining and by the time you have enough glue to overcome the dust you will have a soggy mess.
