The ABS does it's checks and works when it is supposed to.('98 LSE) Today it came on a couple of times after I went around a (fairly) sharp corner. The light would come on and only reset when the ignition was turned off. After that the checks would go on then the light went out at 5mph. I haven't checked tire pressure today, but they were correct two days ago before taking a 130 mile trip. Can I clean the sensors at the wheels ?? The workshop manual says they must be replaced if removed !! Last weekend I tried to clean most of the crud off the underside using GUNK and then steam cleaning. It didn't lightup until today...been fine all week. Any suggestions on where to start looking for the problem ?? Thanks in advance for any info.....
Paul Zwerner
Paul Zwerner
