1 - 2 of 2 Posts
Thanks in advance for the help...
I replaced my battery today in a 2006 Range Rover HSE. I replaced at Auto Zone, correct battery, put power in to OBD port.
When I opened the door the alarm went off and after I placed key in ignition and started alarm went off. When I got in the truck no faults were showing everything looks fine. When I go to pull away I notice I have very heavy steering, power steering does not seem to be working. The doors will no longer lock, the back tail gate will not open and the easy access with steering wheel is not working. Key remotes not working either.
Do I need to do some type of reset? Any help would be appreciated....
Thank you
1 - 2 of 2 Posts
