My late Classic has devellopped a metalic knock from the rear end. It happens when the vehicle is given a small, sharp rock, like climbing in and out. It sounds like someone flicking an empty tin-can, and seems to be eminating from the chassis at the inboard joint between the rear cross-member and the left main rail.
The anti-roll bar joints and A-frame ball joint were replaced less than a week before the noise appeared, but seem to operate smoothly. The 2 rear fuel tank mounting bolts have been re-tightened, as have the rear body mounts (which appear to be in good condition).
Has anyone experienced this problem before or have any ideas on what it may be?
