1 - 10 of 10 Posts
My 96 disco has a knocking that occurs at abot 1700 to 2200 rpm's. Only whem Im on it a bit up a hill or trying to accelerate just a bit a mechanic listened to the engine I thought it was maybee a valve but it sounds like its coming from under neath maybee the cat converter? I dont feel any vibration and it runs perfect other than the knocking. If I drive it like a baby it will not do it all. Thanks for your help
If it is a cat, replace it as soon as possible before it ruins an O2 sensor. If it is the driver's side cat, I have an aftermarket one I bought but ended up not needing it. You can have it for the price of a case of Corona, plus shipping from 95356 (Kalifornia).
I have two of them but I am not sure it will fit the passenger side. I will measure it tonight for you if you need the measurements.
That will be great I will get in the shop asap and have them take a look at it Maybee hold off before you go measure I want to make sure thats what it is but if it is ILL TAKE IT FOR SURE. Thanks Jason
How can I check to see if its a cat what would I look for or listen for
Wheeler
If you are in Colorado don't take it to the stealership!
Check out JCRover 4x4,,, you'll get honest advice & best pricing in town jcrover4x4.com or 720/227-9118
Discussion Starter · #6 ·
First SLC yes Jeff is the best remember you and I are the ones who were on the post to take him all of your problems in Denver I had it in last week but this is a new problem
Son of Lucas - Thats what I thought so I have used 91 Octane and cleaners no help same as when I use 85.
1 - 10 of 10 Posts
