1 - 2 of 2 Posts
Bleeds Green
Discussion Starter #1
I changed the oil in my wife's 2014 L494 3.0L last night. I noticed some orange goo dripping down the driver's side of the bell housing. It looks like it's been going on for a while. It's pretty waxy. What the heck could it be? We bought this Range as certified used from our local LR dealer about two years ago and have never had it serviced anywhere other than at that dealer.
92039
92040
Looks Like a Coolant leaks. You must have a water pump failure. if it is You're going to need the following parts to repair it.
-Land Rover LR4 Range Rover & Sport Supercharged Water Pump 3.0/5.0L Genuine OEM (LR073711) $254
-Land Range Rover Sport Thermostat 3.0 V6 OEM Genuine (LR117568) $103.95
-Land Range Rover Sport Supercharged Thermostat Top Hose Crossover Tube OEM (LR092992 & LR090630) $120
-New Thermostat to Engine Tube Heater Hose For Land Rover Range Rover Sport ( $35)
-LAND ROVER OIL COOLER OUTLET PIPE SEAL O-RING RANGE ROVER SPORT (LR030593) $10
(some Water Pump Kit has this part already included)
-Land Range Rover Sport Bleed Plug Water Pump Thermostat Crossover Tube Pipe $12 (some Water Pump Kit has this part already included)
I also replaced the 2 Belts.
-LAND ROVER RANGE ROVER SPORT 2014-ON 5.0L PRIMARY and SECONDARY BELTS
1 - 2 of 2 Posts
