1 - 15 of 15 Posts
The Urban Motorist
Thank you every much for the post.
Hopefully, this will solve more problems for the rest of us. Thank you for looking out.
Adam in NYC
My 2000 discovery will not start. It has a new battery & alternator is good. Never any problems . Any ideas?? Thanks
This codes relates to ECM activity in terms of correcting a rich or lean fuel mixture. Your particular code is: Maximum Positive Air Mass Flow Rate (AMFR) correction fault. P1179 is the other end of the scale is Maximum Negative AMFR correction fault. It would seem you would have to investigate the reason your fuel mixture is beyond the correction abilities of your ECM. First, make sure you have a clean air filter and replace it if it is time to do so. Next, check for leaking or cracked intake manifold hoses and check for intake manifold leaks by spraying starter fluid around the base of the intake manifold with the engine idling. Finally, check connections to the Mass Air Flow sensor and clean the MAF sensor wire with CRC sensor spray. Beyond these simple steps, the next steps would require removal and cleaning of the throttle body, but in most cases the steps outlined cure the problem. Good luck!
1 - 15 of 15 Posts
