I'm wondering if anyone else has run into this issue or might know what could be causing it because I'm stumped.
I purchased the shuttle valve seal kit from Falconworks as I was already replacing the modulator switch and I could tell there was a small leak happening over time because the coating on switch wires was starting to break down. After doing that and then bleeding the brake system, I am now getting a very noticeable leak of brake fluid from the valves that is pooling underneath the ABS unit (picture attached). I know these are prone to leak, but never this much. I've taken it all apart again and inspected the valves and put new seals in and I'm still getting a leak, even before bleeding the brakes.
Any idea what could be causing this? Hoping I don't need to get a new ABS unit as it was not leaking this severely before.
