Hello,
I have a 1995 RRC LWB and everything works except for the tach.
The tach works but doesnt register correctly. When the motor is running it registers 1,000 rpm. I have a tach/dwell meter that I use to verify rpm and it shows 725 rpm. When I shut the motor off the tach needle doesnt return to 0 but instead freezes at what ever position its at. When I rev the motor the tach will move very slowly and doesnt register correctly. If I rev to 3,500 the tach will only show 2,250, and takes forever to move.
Any ideas as to what this may be? Where does the tach get its signal from?
Thank you.
I will try to post a video showing what Im seeing.
Thank you.
