1 - 2 of 2 Posts
I have a 2011 Range Rover (L322)
Has anyone ever installed longer wheel studs in their wheel hub?
I have a set of wheels I am installing and I am not getting enough turns on the lug nut for it to be safe. Only getting 5 full turns and I need at least 8 full turns at a minimum. Therefore I need to install extended wheel studs to get those extra turns.
Has anyone done this and if you can you recommend a reputable vendor from which to order?
Thank you.
Thank you.
Hi, I also have a 2011 L322 Supercharged. Did you ever figure this out? I need longer studs too to fit spacers.
Thanks
1 - 2 of 2 Posts
