My 2003 Disco seems to have lost power. I notice it while trying to accelerate on exit ramps or passing (ie. going into overdrive). It is extremely sluggish and strains to go up hills. It feels like your pulling a trailer with a pallet full of bricks in it. Going up hills it shifts into overdrive and barely makes it. On flat services it seems fine and seems to run fine other than this very noticeable reduction in power.
Background:
- I have an Ultragauge and am runnin NO CODES!
- D2 has 111k miles with an engine that only has 35k on it.
- Has an ARB steel front bumper, rack and slightly oversized tires but I firmly believe this does not account for the significant loss of power
- Seem to shift fine
- I run 93 Ocatane gas and put Seafoam in about every three fillups
-New O2 sensors and MAF within past year
- No fuel filter to check
The only thing that has been suggested is that the Catalytic Converter is on its was out or clogged. My questions are:
1) Any suggestions beyond the Cat
2) Is there a way to diagnose this the Cat to see if it is bad?
- I have seen some videos of people drilling small holes on either side of the cat and measuring pressures to see if its clogged? Is this the way to go?
- Someone suggested taking the O2 sensors off and tie them up for a temporary experiment to see if the power restores after releasing some of the pressure before the cat. If so probably the CAT. Does that make sense in terms of a reasonable diagnostic?
3) If it were the Cat would it not give me some codes?
4)Would a muffler shop be able to tell if it is the Cat.
5) I understand I have 2 Cats off the Y so I would prefer to make sure its bad before shelling out the bucks.
I would really appreciate any help. If I cannot get it figured out before Friday she wont be able to join the family on the beach Vacation. I am just not sure I can do that to her.
Background:
