Hi all,
I have a 2000 Disco II, 178,000 miles. I am having low oil pressure lamp that comes on about 60% of the time on start up. I can make it go off usually by throttling it some. I can hear that the engine is not getting oil. I need help diagnosing this issue please.
A couple of details...
used small amount of seafoam in crankcase during fall, oil lamp started coming on within a few days of this
2 lean codes currently p1171 and p1174
oil pump failed 4 years ago, I installed new one
last week I checked the oil pick up strainer, it was clear, oil good.
changed to a new fram xg16 filter with 10w30 synthetic, oil level full
the problem is a bit intermittent but is always and only at start up
What should I do next?
Should I pull the timing cover and eyeball the pump gears, would I be able to tell just by looking if I got another defective oil pump? Can an oil pump gradually fail? I don't have overheating.
Is this problem bigger ie bearing clearance, but my problem is only on start up?
I don't want to lose my engine here, so any advice would be greatly appreciated!
Thanks,
-Heather
Thanks,
-Heather
