1 - 20 of 22 Posts
Hello,
Is there a source for a LPG conversion kit in the US? I have been trying to contact a place in England for a month now.
Thank you,
The Clean Air Act won't allow a DIY conversion kit anymore. Only an EPA certified installer can convert your rig.
Has anyone state side converted from Gasoline to dual fuel or LPG? I know our brothers on the Isles and in Oz have been doing conversions for a while. In light of the coming fuel hikes coupled with tax incentives for such a conversion, I've started to explore this possibility. My number one question is: What's the cost to convert? I have a good idea of the resultant savings.
Series Moderator
Papaquebec said:
Hello,
Thank you,
Hi Pat,
I can supply gas kits now new or used,sorry about the last one the computer got a virus and have only recently got it back.mail me if still interested.New kits are around £600 plus shipping for carburettor and £650 for efi (p38/disco 2 models on request)
ONz
Series Moderator
Can supply kits,price is dependant on location due to shipping costs,over here in the Uk LPG is less than half the price of petrol, my rangerover on gas is cheaper to run than my 2.0l BMW
I've heard there is a kit out that mixes LPG with diesel to give much better mileage,i mproves performance, along with healther results for the wallet. If anyone is interested, I'll find out more about it and post the results. I will be away for a few days so don't expect a quick reply.
Well, not sure if I should admit this or not but, other than the Land Rover, I do have a F350 Power Stroke Diesel. They do have propane injection systems that will mix the propane with your diesel. You can set the rig up to open when under heavy strain or you can manually switch the system to spray for that "nitrous" effect.
It really does a fantastic job... especially pulling heavy loads up an incline.
I chipped the truck, pumped up the turbo, changed out the intake and added the down pipiing and larger exhaust to decrease the temp... Fastest diesel I have ever driven.
Find yourself a Diesel Performance store... many out there. As for Land Rover applications... should not be a problem.
Polish and proud of it.
I would Love to do that to my Disco II . But I don't know of any place in CT USA to refill the truck .
And where will the tank go ?
I know of kits in Poland that they just take your spare tire out of the trunk and stick this round tank in the spare tire location.
Profesional Hunter
This Kit is manufactured here in SA and is exported to Aus & NZ.
It is made by a company called Seagull Engineering. I could not find them on the net though.
I saw a program on our Local TV where this comany sponser a Mercedes 270CDI in our local Stock car races. (As marketing for their product). in Standerd form the Merc puts out something like 120 KW. After the LPG kit was added it puts out 160kw. (The rules state that no mods on the enjin may be done, but that you may run deul feul. Also you may not add any Oxsidants to the enjin - as in compressed air).
I'm about to get my uncle send me a kit from europe .
Cause I already have 3 people that want it on their cars here in CT .
Only thing is that LNG and CNG are different . LNG is like 97 octane , but CNG is like 85 octane .
can someone explain what LPG is? I keep seeing it on the forums but have no clue what it is or how it works. Any info would be appreciated.
- AppStateDisco
Profesional Hunter
Liquid Petroleum Gas - As in the stuff that you use to cook on when camping.
It is normally added to the air Fuel mixture just before it enters the combustion chamber. Helps incresing power or decreasing fuel consumption.
Well I finaly got some info . And I'm still working on details.
LPG tank so far is a PITA . Casue it needs to be US DOT apruved all that happy hourse **** :) . The electronics and control valve end is taken care off. It will ruffly cost about $700 , and then the tank or tanks will be additional ~ $300. So now I'm stuck on the tanks.
Anyone has any good ideas where to stick a tank or tanks under that thing ?
Cause 44" x 8" cilinder is really tiny . it dose not hold that much . But I have to do more reasurch . Casue I know that they run tanks that go into the trunk where spare tire was .
And LR needs to use liqwid , casue Compresed is only like 87 octane , when Liqwid is like 97 or 95 octane.
Former LR tech, Albany NY
you could stick it on the side in the back and run the lines thru the floor and seal them up with a grommet.
oh and chipping a ford diesel can have disastrous results. heard alot of stories from the diesel guys I hang around with.
Global British Inc
LPG duel fuel - yes i sell them in Canada!
Papaquebec said:
Hello,
Thank you,
I brought my 87 RHD vogue with me from the UK its duel fuel gas propane (97 4.0 4 bolt with serpentine drive). 5th year of running in Ontario starts in minus 35c no issues - as i use my rangie for logging etc
Runs better on propane than gas and i have a supplier for the kits two types simple changeover kit - shuts off gas pump and switches in LPG when warm or latest Italian style with fuel rail 8 propane injectors and own mappable ECU that sources signals from O/E
Email me for details.
Cheers
Dom
LPG in Mass.
Hello, I have been wondering for some time about switching to LP. A few years ago it seemed a bit steep, but am hoping that maybe costs have come down. I have 2 Disco IIs so maybe it might be a little cheaper and easier to do 2. I can learn from the mistakes on the first one. Hope someone might have info about LP in the Boston area.
Thanks,
Easton Rover
I am very interested in this also....I don't know how accurate that earlier post about not being EPA approved is, I think some things have changed!
I am still trying to also find out some more as far as my state is concerned on these conversions!
Here is a good source I think...looks like they have good support and knowledge on the Land Rover V8's!
Its a shame, we are behind Europe on this....they have been doing this for a few years already! BTW, 95% of the world's supply of LPG comes from the US!
I'm convinced on the kit....I need to find out about the rest as far as legalities!
v8Dualfuel.com: LPG / Autogas conversions and Kits for the Rover V8 Engine
I am new here! Also new to RR. I sought out this site as a source for some information on the topic of this thread.
I have a 96 P38 HSE in mind that I want to buy. It has been well maintained from everything I have read as far as a buying guide goes. I am taking a local indy mech. with me tomorrow to give it the thorough check before I pull the trigger on my first RR.
I have been wanting one for a while and the purpose I have in mind is just to have a 4X for inclimate weather and the occasional camp/trail ride with my son (just now 18 months old). This will not be an everyday driver but I definitely want to do a sequential bi-fuel conversion for LP gas.
I have searched around to find install techs, kit info, filling stations, and even looked into a home fuel station but I cannot find any single source for this path that is here in the States.
This site seems chock full of knowledgeable LR/RR enthusiasts so hopefully there will be a thread (yes I have searched) someone can point me to or a link someone can provide.
I may not buy the P38 I have in mind right now but I will get one and I do want to run LP.
Thanks in advance guys, and remember, I'm a noob.:wave:
Hi, well...I googled LPG and RR and came up with one website that I posted above 4 u to click on, I found that out of 4 or 5 dealing with the Land Rover V8's that this had the most information and offered a kit for every Land Rover...from the Series to the most recent Range Rover!
Check it out!
You will have to source the under hood kit from UK/Europe because I could not find anybody in the states....then the bulkier tank you can buy anywhere in the US!
Not to say that you could not rig a LPG system into a land rover here...its just that they (UK) have been doing it longer and have custom taylored a kit for the Land Rover's, besides it not the much on shipping... the tank is, but you can buy that here in states!
BTW, there is an unbelievably mint and expensive P38 (2001) on Ebay right now out of Atlanta with only 45,000 miles!
1 - 20 of 22 Posts
