1 - 3 of 3 Posts
Discussion Starter #1
I have an 09 lr2 with 146000 miles on it. While driving yesterday it started making a clicking noise under acceleration then lost all power and wont start now. Oil on passenger top side of motor. Im stumped. Please any anfo would be appreciated.
Super Moderator
Lr2s are kind of famous for timing chain issue
Does it sound normal when cranking?
You don't say if it is petrol or diesel. If petrol, undo the fuel connection from the pump/tank in the engine bay - one is the feed, the other is the return. With the ignition on, you should get a strong squirt of fuel from the feed line. If not, your problem is the fuel pump - probably a broken positive wire under the vehicle somewhere
1 - 3 of 3 Posts
