1 - 11 of 11 Posts
Site Sponsor
Discussion Starter #1
Time to get ready for summer trails and install a 2.5 inch lift kit from Johnson Rods.
We have a summer sale going on now.
It's also a good time to upgrade to 18" wheels and we can set you up. Check our website for details.
LR3 Lift Kit, LR4 Lift Kit, Johnson Rods
LR4 with Johnson Rod lift and Satin Black 18" wheels
[/IMG]
Site Sponsor
Discussion Starter #2
LR3, LR4 lift kit
Lifting your LR3, LR4 has never been so easy. This is an install you can do yourself in 30 minutes.
This lift will not only make your truck look better, it will provide you with an additional 2.5 inches of lift which is great for off road.
Our lift is used by Land Rover dealers and independent shop as the best way to lift your vehicle.
Also, Check out our 18" wheels to improve your tire selection.
Johnson Rods 2.5 inch lift on showroom vehicle at dealership:
[/IMG]
Site Sponsor
Discussion Starter #3
Lift your LR3 or LR4 to improve off road performance
Check out our website for more information on lifting your LR3 or LR4.
Get larger tires for off road or street use.
For off road, upgrade to 18 inch wheels. Check our Compomotive wheels specifically designed to fit the LR4 with no modifications.
[/IMG]
[/IMG]
What size tire on the dark grey truck? Is that about as large as you can go? It looks like the rear wheel opening is more limiting than the front.
member
Site Sponsor
Discussion Starter #6
LR3, LR4 2.5 inch Johnson Rod Lift with larger tires
With a Johnson Rod 2.5 inch lift kit on the LR3 you can go with a 32 inch tire and the LR4 a 31.5
For the LR4 if you get the 18 inch Compomotive wheels you can fit 32 inch due to the added negative offset.
I recommend the 18 inch wheels for off road use. Much better than using 20's and more selection.
[/IMG]
Site Sponsor
Discussion Starter #10
LR4, 2.5 inch johnson rod lift kit 18" Compo wheels
Time to get ready for summer. Lift your LR3, LR4 with a 2.5 inch lift kit from Johnson Rods.
Get larger off road tires. Check our Compo 18" wheels for more tire selection.
We are the number one supplier of lift kits world wide for Land Rover vehicles.
Get yours here: LR3 Lift Kit, LR4 Lift Kit, Johnson Rods
[/IMG]
1 - 11 of 11 Posts
