I just purchased a 2008 LR3 SE. The guy before me said the battery will just die - while driving and letting it sit. I replaced the alternator with the OEM original and that took care of the battery light on the dashboard. But the battery would still die after sitting 1-2 days.
I ran a draw test - setting at 10amp. I am drawing 3.12 amp I guess if I am reading this right. I thought the draw should be .012 when off. I removed the radio and the draw went down to .66. But then I was noticing different fuses pulling a little here and a little there and some .5 or higher - mostly related to the radio for the higher pulls. Well this didn't make sense to me - many fuses pulling a draw.
I decided to compare to my 2006 full size range rover. On that car (much more electronics) it is pulling 3.6 amps while off. I have NEVER had a battery die on that car and it has sat for a week or so without starting.
So now I'm beginning to wonder if this is normal with these cars and that the battery I have is just bad. It is a new battery but was being used for a week with the older bad alternator. Perhaps that alternator destroyed it. I will have auto zone check it but I'm wonder if the battery Autozone gave me isn't compatible with these cars. I heard interstate batteries should be used.
Anyone experience this before?
