Is this drive shaft rebuildable? I am getting a high pitch squeak from under the middle/rear of the truck. The squeak has a frequency of about 4 x the revolution of the rear wheel.
The ring and pinion ratio is 3.74:1
The squeak only occurs while applying the brakes and can only be heard from 5-0 mph, just before stopping.
Also, I jacked up the rear with the trans in neutral, rotated the driveshaft by rotating the rear wheel and had no squeak. Could it just be the brakes? I hope so!
The diff runs fine, oil looks good, oil just been replaced.
I have no vibration, all is well but :helpthe annoying squeak.
2006 LR3
98000 miles
Your thoughts?
2006 LR3
98000 miles
Your thoughts?
