1 - 6 of 6 Posts
Hi all, hopefully someone can help a stressed lad out!!
Any help would be appreciated
thankyou
start: so I purchased a disco 3 (ouch lol)
it had suspension fault/ and starting issues
I eventually found out the clocks where n/s
so I purchased another landy disco 3
and swapped the ecu/clocks/fuse box and tcm and walla it’s starts 1st time
now my issue is my suspension
so on my 1st initial thought, plugged in
came up with rlm vin mis match
so I change the rlm with the donar car
boom all lights went out and suspension working….. for 5 mins anyway
so I goes down road and it goes into extended mode all on its own then some weird like abs breaking feeling came through the car
so I immediately stopped turned off
then went to restart and suspension fault appeared
aghhhh
so far I’ve put a brand new compressor in new relay
checked fuse box in engine bay
checked fuses on new fuse board
checked connection2 under passenger rear wheel arch no joy what’s so ever
also got my hands on JLR which really doesn’t help either but I tried
so if anyone wouldn’t mind pointing me in another direction to try I would appreciate it
big thankyou
very disco
Have you pulled codes
very disco
What diagnostic equipment do you have? If you swapped all of these computers, it’s entirely possible that they’re not happy together.
1 - 6 of 6 Posts
