1 - 6 of 6 Posts
Hey y/all
Any 1 ever use lucad gear oil additive I guess its for motor oil too I put it in when I did a change the other day suppose to make oil last longer run cooler ect ect Let m e know if ya all tried it
thanks Eric
How much do you use?
Hey Dent, How much Lucas oil do you use when you change your oil? All so do you ever use an engine flush before you change your oil? I used it all the time on my VW Jetta. It is to break down all the sludge and clean it out when you change the oil, but you have to start off with from the beginning. If you use it after 60K on the engine. You might damage the oil seals and gaskets.
usually add the bottle to every oil change. don't usually do an engine flush as i'm pretty anal when it comes to oil changes and as such i don't think it's sludgy. add a bottle per oil change. helps alot with the typical land rover oil leaks. also used the power steering one too.
take care
sam
1 - 6 of 6 Posts
