1 - 8 of 8 Posts
Can't figure this out!!
First off 04 130K ran fine before this
Now no drive indicator by dash and m&s flashing
Thought it may be xyz switch. Changed it and still the same.
Checked grounds and ran new grounds from battery
Had the alternator checked and changed battery.
Why is there no indication of which gear I'm in on the dash? It just disappeared
Any help on this would be greatly appreciated
04 SE7 95K
04 SE 130K
'03 Disco SE
M&S lights flashing are indicative of a bad battery, bad XYZ switch, bad transmission ECU, or a failing transmission. Considering you've already done the first two, I'm leaning towards bad ECU/bad trans, but before you throw parts at it get a scanner and read the codes.
The car should be throwing a code - get the code read and come back to us with the results.
I had similar issues last week and now she's stalling on me when she gets up to temp.
No faults showing and no other warnings except the occasional knock sensor fault. I swapped out the knock sensor, but that didn't fix it. Going to swap out the crank sensor tonight.
Do you have any fault code numbers, if so what are they?
Is the tranny shifting properly?
i have no faults of any kind and tranny shifts fine.
when my m&s lights were on i was getting a knock sensor fault code. currently i have no faults or lights, but she just turns off after she gets up to temp.
Need actual fault code numbers to be able to help you.
Discussion Starter · #7 ·
My disco is still at the shop where I had the alternator checked but I will advise tomorrow with codes. I am also leaning to bad tcu or bcm maybe? I have noticed some weird things since this started like the truck not restarting after turning key to off then back on. I have to lock doors and unlock with key fob for it to start. It doesn't shift, it's in limp mode and as I said no gear indicator shows at all on the dash.
as for mine.. i swapped out the cps last night and my 20 minute test drive was a success.
i'll driver her around some more this evening, but i think she's cured. for now ;)
1 - 8 of 8 Posts
