1 - 4 of 4 Posts
Hello all,
New to the LR3 and new to this forum.
I am starting to get the P0171 error on my dash.
I tried to find the cause by looking for leaks but to no avail. The local mechanic used maf sensor spray to clean - and this seemed to work for a while.
On the freeze frame data:
MAP(kPA) was 80
rpm 2307
maf (g/s) 59.74
Baro (kpa) 101
Does this data look right? Any suggestions?
you could try cleaning the injectors as well - that's a common problem that will get that error...you'll want to use a pressurized fuel rail cleaner...you can find youtube tutorials on it.
member
Go to some one that does the BG one.
1 - 4 of 4 Posts
