21 - 40 of 50 Posts
Hi! I am new to the forums, too. I just picked up a 2000 Disco with 119k. The previous owners were meticulous with the maintenance and keeping records. They have a spare engine and offered to let me have parts from it if I wanted. I am pretty clueless about that kind of thing. Can you recommend any engine parts I can take that might become handy down the line? Thanks for posting the high mileage maintenance schedule! That is excellent!
Hello....I am new to the thread:) But wanted folks to know that I had an on going problem with leaking coolant...I finally had my 03 Disco with 181,279 miles original head gaskets & spark plugs replaced...and omg the truck runs so much better...no more leaks...Having to ride around with a bottle of coolant for the past year...has been a great relief..for those who don't think the Disco will run past 150,000 miles...I am living proof..Prior to the head gasket work being done...I had the valve covers replaced, water pump and thermos. replaced...but I kept having this leak...
Where is the leak at? Anyway, check the throttle body heater just in case. I had a leak and that was the issue. Easy fix.
I have an 04 disco II, I need to replace the radiator but only see "without secondary air injection" on the description on internet. I have SAI. Thoughts? kevin
Anyone notice the note "Check/Adjust" the steering box ??
Is it adjustable?
Service
Thank you so much! You are a blessing.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil, Shell Rotella T-6
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Castrol Synthetic or Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic Power steering fluid
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of B&G’s 44K gas additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant Pressure Cap and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Rebuild or Replace the front drive shaft if it only has 1 grease fitting
Hopefully I didn't leave anything out.
Administrator
Discussion Starter #28
Make sure that you replace your coolant pressure cap and t/stat cause they do wear ot, especially with DexCool.
Administrator
Discussion Starter #30
How about 50% coolant and distilled water or buy the 50/50 premixed coolant.
When doing that make sure you add a new 180 degree t/stat for better cooling.
What are your thoughts on changing Trans fluid on high milers? Saw somewhere they said don't touch it if it has high miles and never been changed before.
Just bought a 2004 D2 with 124K. Appears it was taking good care of, but getting ready to do major service as a preventative and a baseline.
Sent from AutoGuide.com App
I'm trying to track down two leaks from under the d2. Looks like coolant and power steering. Are the plastic "plates" necessary? They are in the way, and I can't seem to remove them without removing major items. Can I just cut them out and throw away?
2004 Discovery 2, 124,000 miles.
21 - 40 of 50 Posts
