1 - 2 of 2 Posts
I am the proud owner of a Discovery with a cracked manifold. Been through this once before with all the fun of drilling out a broken bolt from the rear bottom passenger side manifold.
At the time I found a good deal on both set of manifolds. After changing out the passenger side, I have a hesistance to tackle the driver side.
My question is....
Has anyone used those Brazing Rods for repairing a cracked manifold without removing the manifold? The crack is on the top side and seems accessible from the top.
Former LR tech, Albany NY
you know we were replacing them under a recall a while ago. It involved and inspection of the passenger side manifold and then replacement.
If you want to weld a manifold you need to make a jig otherwise when you take it off you cant guarantee it will work in the first place.
I welded one on an old explorer. It held for a while though. Truck sat around for a year and sat again for another year.
1 - 2 of 2 Posts
