1 - 3 of 3 Posts
I was asked, yesterday, at the local British Car day event in CT about installing a mechanical water temp guage on a Rover V8 engine. I did this on my Defender, but it would be the same for Range Rover classic, and 3.9 Disco.
Without looking at the intake manifold on my son's XD, I couldn't say for certain that it will work on 4.0 Discos and Rangies, or 4.6 engines, as I don't have their intake manifold so indellibly burned into my brain.
Any way, If you take a look at your intake manifold, in the front, right corner, you will see where the electric water temp guage sender is tapped into the manifold, horizontally. Above it is a flat boss, with nothing there. That is where I drilled and tapped a 3/8" FPT hole, into the same pocket in which the electric sender is mounted. Most aftermarket mechanical guages come with adapters for installing their capillary tube sender, usually in 1/4", 3/8" and 1/2" MPT. The half inch adapter is just borderline too big, so the 3/8" was just right. I did this when I had the manifold off, set up on the Bridgeport miller, but if you're carefull, it can be done in situ.
Hey Terry,
Can I bring my manifold over and have it drilled?
Too bad I didn't know about the British card day, I would've loved to have attended. Oh well, maybe next time.
Yes, I'll be happy to do it, and yes, it's too bad. It was held at Harkness Mem. Park, in Waterford, literally a stones throw from the waters edge. You could just hear all that British Iron quaking in fear of a salt air breeze.
Between my son and I, I think we own 20 or more cameras. Do you think either one of us Dumasses would think to bring one?
1 - 3 of 3 Posts
