1 - 2 of 2 Posts
Hey all, need some info on this conversion. Does it work? Has anyone done it?
-Will using the "hub centric shim" get rid of all the vibration?
-Do you have to calibrate the air suspension to accommodate the 19' wheels & tires? What setting is needed for the vehicle to sit "just right" (not too high)
-Does the air suspension need to be lifted? If so, how many MM?
Basically I am looking for a concise description of the entire process
I'm looking to do the same with my 2000 D2. I've been told that the only thing needed were the hub centric rings to stop vibrations. I have also seen a D2 with the Rover 20's. Depending on the tire size you shouldn't see a difference.
1 - 2 of 2 Posts
