1 - 2 of 2 Posts
Former LR tech, Albany NY
The water pressure probably overwhelmed the seals. Sometimes you can clean them up and put new sealant into them. Depends on the design.
On the fog lites just open the cap and let it drain.
but its possible if enough water is in the lites the caps on the back of the lites are missing or loose.
Just take off the three screws on the front grill pull the grill and then remove the two female torx screws on top and the one number three philips on the bottom holding in on and check to see whats up.
you can also do that just to dry them out if you want to.
1 - 2 of 2 Posts
