1 - 7 of 7 Posts
If some of you read my earlier post on NYE on had an issue with a P0301 misfire code that comes on and off on my 2001 Land Rover D2...stays on for a few days then is off for a day or two. I was ruling out plugs and wires but figured I will just order a thicker set of 8mm kingsborne wires and bosch dual platinum +4 spark plugs.
I am thinking about taking the upper manifold off and checking the fuel injector, swapping my number 1 fuel injector with another cylinder, while having it open I was thinking of just replacing the coil (bosch coil that I found for $60). I heard that the fuel injectors are pretty robust in D2s. What are your guys thoughts? Do coils typically go first? Fuel injectors more of an issue? Should I just replace both the fuel injector and coil? OEM fuel injectors can get up there in price so thats why I am thinking of starting with the cheaper of the two....
I am just hoping its the wires and plugs that will do the trick but starting to think of other things it could be because after the plug swap, and wire swap I keep getting P0301 which is telling me it might not be the wire or plug....all the help I can get would be appreciated. Very annoying when you can't pin point exactly what the problem is but I am trying to save myself money by doing the cheaper tests first...
Hope everyone had a happy new year....cheers Marek!
Your on the right track. Start with wires and plugs first. Just stay with the +2's. Next, swap the coils side to side and see if the misfire follows the coils, then the injector swap with another cylinder. Narrows it down before you have to buy anything.
Helievacpilot: from your experience....just based off of what typically goes 1st in the D2...has it been coil or fuel injector? i am just curious, if it were a guessing game, I will eventually pin point it exactly after swapping parts out. just curious as to past experiences because i have only had my land rover since Oct
Not seeing that much on +2's in terms of buying them....is there issues with +4 and kingsborne wires? Many say bosch +4 and magnecor wires...
so many different opinions out there, can get very confusing
Autolite double platinum from Advance Auto. Kingsborne are great. Don't waste your money on magnecor.
Can't say either is more or less reliable or likely to fail. Neither is a common failure item on a D2.
Checking for a bad coil
I know this is an old thread but I thought I add this in case others are chasing the same problem.
Our trucks have 2 coil packs, each contains 2coils. 2packs x 2 coils = 4 coils for 8 cylinders. Each coil fires 2 cylinders. So, if you have a bad coil you will get misfires on 2 cylinders. If you know which 2 you can easily change the correct coil pack.
Cylinders sharing coils: left pack: 1&6, 4&7, right pack: 2&3, 5&8,
The pic of the coil is viewed as looking at the back of the engine as if you were sitting in the truck.
1 - 7 of 7 Posts
