Well, dropped it in, fired it up and ran all ok.
Put the tools away and started it up again, this time it ran very rough and slowly died. Refused to start anymore.
Red battery warning light is on.
I 've got battery voltage between positive battery terminal and negative on the coil, workshop manual says should be zero with ignition off.
With ignition on its zero, suspect I've fired the amplifer?
Any ideas ?
