1 - 5 of 5 Posts
1993 range rover lwb - Roman Bronze
I just bought a pair of mud flaps from AB and started to install them.The problem I saw was the bolts holding it on is not like a conventional bolt and screw assembly...on one side it looks like a round head ( think mushroom head) and the other side looks like a plug of some sort....I tried taking some pliers the the mushroom end but it just spins and spins.....i can't even grab onto the other side.....How do I take these off?:dunno:
If memory serves I just cut off the fixings with a cutoff wheel on an air die grinder. But that was some time ago now, the entire bracket rusted and fell off years ago lol.
Mud flaps
These fixings are called Rivnuts; very similar to rivets. You require a special tool to remove them and install them. Cut them off with a Dremel or similar and install nuts and bolts.
1 - 5 of 5 Posts
