1 - 1 of 1 Posts
Hello all. I picked up a 2012 rover sport hse from an auction and need some help. After a inspection we discovered that the previous owner cut the wiring harness hooked to the ecu along with the canbus wires next to it. To further the damage they also took out all the fuse blocks. We put all the fuses back and hooked up all the wires. It is able to start and drive now but we get so many faults. It also does not shift into gear unless the emergency pin is pressed. Even then it only stays in second gear and doesn't pass 50mph. After resetting all codes we still get lost communication with various modules.
1 - 1 of 1 Posts
