I have a 2002 disco with 104,000 miles. Its engine refused to start today. Could someone please tell me what likely be the problem for this disco with this many miles on this engine? The engine turned over but would not start. What likely be the problem for a 2002 DISCO with 104,000 miles;
1) fuel pump? how do i check to see if the fuel pump is working? where do i open up a fuel line to see if gas is pumped through, or measure to see if fuel pressure is sufficient?
2) Ignition? which part do I need to replace besides the spark plugs and spark plug wires? spark plug wires were place about 5K miles ago.
3) other reason?:confused
Any ideas are greatly appreciated. HArry
