Here is the news. I posted about the throwout bearing wrecking the trani. The correlation betweeen the two was maybee no transmission fluid was put back in after the throwout was replaced causing the trani issues. Now that does not seem to be the case.
But here is what was found wrong with the truck.
I am writting everything as it appears on the computer print out I was given yesterday.
1. Transmission conearn:
transmission bearings very noisey, 2nd gear syncro bad, will require trani overhaul or replacement to repair.
2. ABS concearn:
Anti-lock light is on, sensor bad. Will need new sensor to repair
3. Oli Leak:
Engine has numerous leaks, valve cover gasket, oil pan reseal, front and rear crankshaft seals, oil cooler line, and drain plug
4. Tire concearn:
All tires are dry rotted (how can I confirm this)???
After reading this all comments and suggestions would be greatly appreciated. If any of you have had any of this work done could you post prices you paid.
p.s. go easy new owner and new to the site.
2. ABS concearn:
3. Oli Leak:
4. Tire concearn:
