1 - 7 of 7 Posts
I have a 2003 land rover discovery II and one day when I was visiting a friend I went out to my car and it turned over fine but it would not start. The day before I drove it fine to get to their house but the next morning my car would not start.
I have changed the fuel pump and that didn't work, I changed the crankshaft position sensor and that didn't work either and I am running out of options on what it could be. I visited other forums to see if other people were having the same issue which they seemed to be having, but these solutions aren't working for me. So I will take any advice at this point on what the issue could be.
disco biscuit
Does it have any codes stored. There's an inertia switch on the firewall on passenger side. That's a free thing you could check. I would also check for fire at the plugs and suspect coils. Also did you check fuel pressure on the Schrader valve on the fuel rail? I assume you did if you justified the fuel pump. Its safest with a intended gauge but I've done it with a tire gauge. Don't blow yourself up. I would try to trouble shoot things from here on out. I like changing old parts but guessing can be expensive.
I just took it to a shop to get a second opinion and the mechanic told me that I would need a new engine which would easily cost me a couple thousand. I didn't take him seriously because I doubt my engine would just quit on me randomly one day without any warnings or anything like that. I recently changed the head gasket a couple weeks before because my car was overheating and it blew on me, but after I got it changed my car was working fine until I came from a friends house and tried to start my car and it wouldn't start. I still have to check the plugs and coils and I will keep you updated on what worked and what didn't.
Get the shop manual and figure it out, it's probably something simple like a connector or ground. Just Don't freak out yet. Two things make me think the mechanic is full of **** first is that a new engine will cost you more than a couple grand and it doesn't't sound like he gave you a specific cause, engine is pretty vague.
The manual is priceless, just go through it.
Discussion Starter · #5 ·
Would the fuel filter need changing? I saw a video on youtube saying it could be a bad spark plug but I haven't been near my car to check it out. And I don't know where the fuel filter would be located.
1 - 7 of 7 Posts
