21 - 32 of 32 Posts
While it's in P it might be different that's why investigations are needed... are you handy with electrics as to make continuity tests on the circuit?
  • Like
Reactions: Bigmant773
2002 Land Rover Discovsry
Discussion Starter #22
Not really haha. But the Ultragauge can read RPMs off the OBD port!
Discussion Starter #23
What am I looking for in park? Just no fluctuations? What’s the tolerance for the fluctuations
read again post #19 ... no tolerance, the CPS reading must be linear
Return the iLand and buy a Nanocom.
Not normal. The idle must be steady
  • Like
Discussion Starter #28
Ok this is good, we’re making progress then! So are we saying the crank position sensor is bad then? My plan is to spray engine degreaser down there to clean the area up real well, disconnect the sensor, clean the sensor and the plug with QD cleaner and then reinstall. If I still have the same issue, I’ll buy another one and retry. I’m thinking maybe one of the pins is clogged with gunk from the install, because it was filthy down there.
Thoughts?
Discussion Starter #29
Alright well I found this as I pulled my new Crank Position Sensor Out:
92434
No idea what, or from where that little ring came from, but I’m guess that might be causing my problems. I’m cleaning everything up to make sure the connectors are clean and then I’ll reinstall.
Anyone know where that small spacer goes or came from?
Super Moderator
Looks like a reinforcement ring from a valve cover gasket.???
Regardless it shouldn’t be there and would likely goof up the sensor
very disco
Ominous to say the least!
Discussion Starter #32
Update! That must have been what was gooning up the sensor! Cleaned everything real well before disassembly, and then cleaned all the connectors with some QD cleaner. I have a feeling it was that ring though. Runs like a top! Thank you everyone for the help!
21 - 32 of 32 Posts
