Hi all. I bought my 2000 Disco II last Friday. It had a couple of maintenance issues that I would need to address but the price was right so I went for it. The issues were bad actuators in the windows, the three amigos, and an ac fan not engaging allowing the engine to run hot in certain conditions.
The big issue for me and the one I need to address is the fan issue. On reading up for the past week or so, it seems like Disco IIs blow head gaskets pretty easily. For the most part, the engine runs at normal temp and never goes up past half way. It does tend to creep up in certain conditions that would be consistent with a non-engaging fan. This morning, I was stuck in traffic and it creeped up on me. I flipped the Disco around to go another way and the temp did drop back closer to the normal running range but it did want to run hotter for the rest of the trip, (anywhere from 1/2 to 2/3). I have done some searches on the fan issue but there really isn't anything that stands out as some sort of common issue that I should look at first.
Symptoms note:
The AC blows cold.
The coolant levels are fine including the expansion tank.
Also, I am a bit confused as to what coolant I should be adding. According to Disco Mike's high mileage sticky, it's not DexCool but the traditional green coolant. I read on another page where they recommended DexCool. I imagine there is a reason why this information is conflicting.
Thanks in advance,
Symptoms note:
The AC blows cold.
Thanks in advance,
