just bought a 2ooo disco 2 cheap has bad leaks but motor runs very strong for 147,000 miles it has ace and its pumps leaking also the ft main is also leaking at the tranny pan and i just found out the ft propeller shaft was changed due to it snapin at the uni joint and it seams that they must have replaced the pan after the driveshaft smacked it also the pan has way too much rtv sealant on too any ideas where to start ???? gasket kit /ace ?? rebuild both tranny and motor???? what yall think guys .....thanks p.Dinino
p.s. the tranny wont manually shift into 1st but in drive it runs all the gears perfect
