HI All,
Just bought an 88 RR Classic- 3.5 V8, from the warehouse next to mine- I've been eyeing it for the last 2.5 years- sitting in the same place, no air in the tires, etc. Finally the guy sold it to me for a GREAT price- said he drove it in one day and it wouldn't start, so doesn't know whats wrong, blah blah blah blah.
To make a long story short, found the little solenoid wire disconnected, hooked it up, a few cranks and vroom!
My questions, if anyone can help or point me in the right direction.... and NO, I don't have any manuals.
What does LWB mean (or is is as simple as "Long Wheel Base")?
How do you tell if you have a LWB?
What size is the oil drain nut? mine looks like a 40mm???
Does everybodys oil hit the exhaust pipe?
Does your RRC start up immediately? I have to crank it for a while, sometimes fuel injection cars start right up-
I read in one of the threads to whack the parking brake drum to free the shoes- mine the parking brake lever does not move, and I can only drive it in LOW range- the thread said "...removed the cover (I'm assuming from inside?) and loosened the adjuster on the drum???? Anybody have a pic of this?
Also read that cables freeze- that could be the case here as well?
My turn signals don't work, nor does the 4-way flaasher? Is this a common thing on our cars? Is there a flaasher relay somewhere? if so, where? I checked the fuse, it's ok.
Any comments on a standard replacement tire? 205/80/16? My local RR dealer in Dayton Oh said- "We don't do tires, you'll have to go to a tire dealer" Don't want to get a tire discussion going, just thoughts on new tires so I don't have to adjust anything on the body.
Where can I get a non-K&N air filter that will fit?
Thanks in advance for any and all help. This looks like a great board and a fantastic group of knowledge.
One more question- is there an adjustment for the front brush guard- mine is pretty close to the grill, the hood hits it going up and down- adjust? or wrap a chain around it and a tree and back up?
Thanks,
Carl
Thanks,
Carl
