1 - 3 of 3 Posts
Hello All,
I have a 1999 Discovery II that following a head gasket repair and replacement CPS will not turn over.
One oddity before going in to more detail is that when I attempt to start despite the engine not turning over when I turn off the ignition I am unable to remove the key from the ignition, only way to remove the key is to disconnect the battery.
The battery is new and fully charged
The starter checks out as OK
The CPS looks good (I believe that if it was the CPS it should still turn over but just not fire up)
All dash lights, indicators, radio, windows work (apart from the rear door lock)
When I do attempt to start it up I get the normal bing, bing sound but then it changes to a fast bing, bing, bing continually and the light on the dash (left hand side (looks like 2 cogs with a line through them) (not sure what that is) flashes.
Any suggestions would be appreciated.
The nearest LR service shop is a 16 hour drive away...
Thank you from Prince Rupert, BC Canada.
Cell 778 645 0254 call collect if you have any bright ideas on how I can get this to turn over..:crying:crying:crying:crying
'03 Disco SE
Assuming the battery & starter are good and all of the various electrical connections are good (particularly battery-engine) then you're probably looking at an immobiliser/security lockout issue.
1. Check that the battery in the key fob is good. If it's gone dead the security system can't sense it and won't let the car crank.
2. Check that the shifter is in "PARK". If it's any other position the car won't crank. The fact that you can't remove the key makes me think that this might be the issue. Move the lever back and forth a couple of times before setting it into park. Make sure the TC is in gear. It could be a bad "neutral safety switch" so the car doesn't know what gear it's in and prevents the engine from cranking at all.
3. Reset the XYZ (inertia) switch on the firewall. Just depress the button under the rubber cover. Sometimes it trips after major work.
4. Check fuses/grounds/connections, etc. Goes without saying but maybe something is loose or you overlooked a connection.
1 - 3 of 3 Posts
