1 - 1 of 1 Posts
Hi everyone, I'm new to the forum and the Land Rover world. Just bought a 1993 200tdi and everything was working well as I started into preventative maintenance. One day, after using the truck several times, I came out to the garage to find it was completely electrically dead. Took the battery to the parts store and it is at 100%. I thought maybe the ignition switch, as it fell apart when I pulled open the dash. I ordered a new and replaced it but no luck. I'm getting voltage to the switch. So took the starter off and tested it. Starter seems fine. I can't figure out how to pull the dash off to follow the circuit. Is there a relay or fuse I should check out next? Looking forward to your expert advice! Thanks.
1 - 1 of 1 Posts
