97 Disco failed to start several times. I usually waited it out (one hour or so) and it would start. Finally it refuses to run at all. Read thread on spider box located under dash, hope I don't have to venture in there. All fuses checked out OK, test light indicates power on backside of fuel pump fuse located under bonnet, pressed fuel cutoff switch as per owner's manual, removed carpet and sound barrier then cover plate on top of fuel tank, removed power plug for fuel pump and turned key switch to on position. Test light indicated no power here. Also depressed fuel pressure bleedoff valve at injector rail and only one drop of fuel leaked out. Anybody have knowledge of this problem or will I be tearing the dash out for the spider box which is part of alarm & disabling system.
