1 - 2 of 2 Posts
provided it's not immoblilised, if you are up to diy you should measure with multimeter if you get voltage on the black/yellow wire at the starter when you try to crank cos if you do the starter is gone(it's own relay), if you dont feel skilled enoughfor that or there's no voltage on tha wire on crank command replace relay pointed with C1455 to rule it out...
1 - 2 of 2 Posts
