1 - 5 of 5 Posts
good morning, found the rr a non starter this morning. cleaned plugs and fit new rotor, cap, and leads but non start continued. pulled lead 1 and passed the block spark test with the result being running rough. replace the lead and non starter continued. repeated all the above for same results. appreciate suggestions as it doesn't make sense to me. thanks.
Discussion Starter · #2 ·
still not starting. now it has new coil, module, leads, plugs, rotor, cap, and fuel filter. new air filter and fuel pump is good. is there a kill/inertia switch on the rr? can the brake light switch kill a start? a f-ing puzzle! thanks
Discussion Starter · #4 ·
1993 4.2. additionally I've just finished going thru the fusable links - and they were ok. it came to life and ran FINE for a half hour - parked it and tried again only to find it dead again. tomorrows another day.
1 - 5 of 5 Posts
